  • 0
king inverter data log
Jurgens
 Share
Question
Good evening I have two questions on the king 5kw OG-plus 5.48 inverter hope someone can help.
1) I have installed 2 inverters in parallel with 4 x 3.5KW pylon Batteries - my question is, do I need to split the data cable between the 2 inverters? I connected the data cable to the rs485 and bms port of my master inverter (setting 5 - PYL)  and do have communication. The slave inverter I set to USE and (12 - 48V) (13 - 51V) (26 and 27 - 53.2V) (29 - 47V)
2) how do I take a data log to see what happened through say the last 2 days? When I connect my laptop to the usb with a cell phone cable I can take a log but as soon as I disconnect the pc then I only have the information that I collected whilst connected, is there a way to get recordings through the day without the pc connected.
thank you in advance
2 answers to this question
  • 0
It depends on the software monitoring them. Usually that software knows how to send commands that refer to the other inverters.
I would think that it would not let you make these settings different to the master. If it does, I'd assume that it would ignore those settings.
Answer this question...
 Share
