July 17, 20206 yr Hi, I'll explain my problem.My solar system is made up of an inverter mppSolar pip gk 5048 4kw photovoltaic power and three pylontech us 2000 batteries connected with the bms option pyl have inverters.Thanks to friend Youde i tuoi the view batteries program .To check the three batteries more carefully. I made the connection cable console port rj11 but the program beat most i can't connect to the bms of batteries. I have done many test, with unsuccessful. I tried rs232 program to the test the cable by send the codes. The batteries responds. Sorry form my bad english.Is there anyone who wanted to give me a tip? Regards Michele Italia
July 19, 20206 yr First of all, you have to get BatteryView working, because it's very complicated to talk to the batteries directly via some other program, like Putty, HyperTerm etc. If the BatteryView is not working these are the common reasons: cable is connected to the wrong port on the battery (CONSOLE is the right one) wrong COM port number selected in the software wrong BAUD RATE selected in the software incorrect cable wiring
July 19, 20206 yr Hi@all I connect sucessfull over rs485 to PylonTech US2000. I can receive a string from pack1. but not from pack2. can anybody help me which byte should change incl. chksum ? the string from manual by pylontech for the 1. pack 7E 32 30 30 32 34 36 34 32 45 30 30 32 30 32 46 44 33 33 0D thx a lot
August 8, 20206 yr I managed to connect my pylontech US3000 to battery view, I saw there were in the history status a “DOCALm” recorded. What is the meaning of this ? The highest current peak was 64A for a short duration, can it be that high discharge?
August 8, 20206 yr Can anyone give me a tip or advice where i can find info on the use of the dry contacts on the pylontech's, I’m thinking of incorporating it to switch my auto-change. Any advise will be appreciated.
