July 27, 20206 yr I've just installed an Infinisolar 5kW Plus with 2 x Pylontech 3.5kWh batteries. But my laptop is not seeing the inverter to adjust the parameters to suit Pylontech. I've used the USB cable supplied with the inverter. Am I missing something?
July 27, 20206 yr Hi Bruce did the Watch Power come with the inverter? Perhaps try Solar Power too. My Infini doesn't work with Watch Power but works with Solar Power. Good luck.
July 27, 20206 yr Author Hi Francois The inverter came with Solar Power which I tried too, but it also doesn't detect the inverter. I also tried two different USB cables without success.
July 27, 20206 yr 2 minutes ago, Bruce K said: Hi Francois The inverter came with Solar Power which I tried too, but it also doesn't detect the inverter. I also tried two different USB cables without success. Hmmm that's strange. Different laptop?
July 27, 20206 yr Author 2 minutes ago, francois said: Hmmm that's strange. Different laptop? Yeah, I'll give that a try.
July 27, 20206 yr See also this thread about pylontech charge voltages: https://powerforum.co.za/topic/2859-floating-pylontechs/#
November 26, 20214 yr I am facing the same challenge, my watchpower can't see Infinisolar 15Kw Inverter. I have tried using both USB and serial cable.
