July 27, 20206 yr Hi all, Been hanging around the forum for a while, but have finally decided to pull the trigger (figuratively, of course), and install a solar system... So far I have ordered bits an pieces to build a DIY battery (18kWh, 48V, LiFePO4). And I have more-or-less decided on a Sunsynk 8kW inverter. Now I need to find some poor sucker to install the solar panels and do the house wiring. Can anybody provide any recommendations for installers in the Pretoria area? Preferably with Sunsynk experience. Thanks, Justin
July 28, 20206 yr 10 hours ago, JustinSchoeman said: poor sucker to install the solar panels and do the house wiring. Why would you need to trick someone or find someone gullible to do this. I am sure there is proper installers that would be happy to help?
July 28, 20206 yr Author 3 hours ago, Jaco de Jongh said: Why would you need to trick someone or find someone gullible to do this. I am sure there is proper installers that would be happy to help? You probably know that it takes a sucker to do a job for an engineer 😉. I don't suppose you would consider a Sunsynk installation?
July 28, 20206 yr 2 minutes ago, JustinSchoeman said: I don't suppose you would consider a Sunsynk installation? If the price is right, I might! I have to see what the Sun's can do. But I dont want to be the sucker though...........
