Damaged Solar Panel. Cause?
Good Day
I have a damaged 200 W solar panel from a customer.
I have attached a picture, can anyone advise what the cause of the damage might have been?
I could be wrong but it looks as if some of the diodes have blown.
I made this mistake once a long time ago (when I was still young and stupid) by connecting a solar panel directly to a battery with no charge controller.
Maybe the customer made the same mistake. 🤔
Thank You Sir. I suspected the same but wanted to get a neutral opinion.
how do you tell that a diode has blown by just looking at a photo? All I can see is a bit of what looks like rust on the first two diodes.
To check a diode one usually uses a multimeter. The resistance selection can be used and one should get a difference when the test leads are reversed. Often mutimeters have a semiconductor resistance selection option (indicated by a diode symbol). This will provide a higher voltage on the test leads to make the diode (or transistor) junction conduct better.
A diode normally will fail short circuit or open circuit.
Agreed
