October 29, 20205 yr Good day to all. Currently I have 3 Canadian solar panels connected in series. (1.5 years old). Want to upgrade to 6 panels eventually, but can only do 1 panel every three months Now. If I add one more panel, can I connect the first two in series, the second two in series and then in parallel to the inverter? I know the voltage will drop, but the watts should increase with +- 400w. The first picture of my dashboard in node red shows my average usage fridge, freezer, tv, internet, security systems and cameras all on The second one is with the aircon on. It was still early in the morning, but from 10:00 in the morning It can generate about 1150w So, adding 1 more panel should (maybe give me a bit more headroom)? Thanks for all the help in the past. I have attached pictures of my inverter specs (clone), but still working, panels and node red Just added the flow in node red (in case someone wants to comment on how I can change all the parameters for charging etc... (it's a work in progress) Edited October 29, 20205 yr by Warlok forgot something
October 29, 20205 yr 52 minutes ago, Warlok said: Now. If I add one more panel, can I connect the first two in series, the second two in series and then in parallel to the inverter? Not only could, you really should.🙂 And when you add the next 2, keep them 2-in-series. These inverters are very sensitive to total voltage - using 72 cell panels 3-in-series is a very bad idea the will almost certainly result in your SCC tripping and may well damage it. (search this forum for @Coulomb's posts to see the details). Your panels will produce over the 145V allowed limit at 15°C. As for connecting them in parallel, one should use a combiner box that has a separate fuse for each string, as well as surge protector and DC breaker. I know that some people just use a Y-connector (much cheaper) - not sure if that is a sensible place to save money. Edited October 29, 20205 yr by Calvin
October 29, 20205 yr Author Thanks allot Calvin. So that could be a Voc of 94,4v and 1600w?. (not calculating losses). Just saw today that my batteries are not so well anymore. Used to get about 3 hours @ 500w 30% DOD and now it's only running 1 hour and 80% DOD. I have been looking at them very nicely but after 1.5 years this is it. (Allgrand 6-cnfj-100). The supplier promised me this was the best batteries ever. I was stupid and wont make the same mistake again. Suppose a Pylon battery is the next move. How good has your batteries been? Edited October 29, 20205 yr by Warlok Added text
October 29, 20205 yr 1 hour ago, Warlok said: So that could be a Voc of 94,4v and 1600w? Correct. 1 hour ago, Warlok said: Suppose a Pylon battery is the next move. How good has your batteries been? I have now been using my Pylons for about 10 months and capacity loss so far is less than 1% so I am happy with them Like all Lithium batteries they treat you well if you treat them well. Don't overcharge, don't keep fully charged at high temperatures too much. In summer I normally only charge them to 70% (discharging to about 40% overnight) and they (and the inverters) have their own air conditioner to keep them below 25C. Once every 2 weeks I take them to 100% @ 52.6V for half an hour to reset the SOC counters. There is also the option of "second-life" batteries - https://lithiumbatteriessa.co.za. Some good reports although they always seem to be out of stock.
October 30, 20205 yr Author Thanks again. You've bee a great help Bought 1 more panel today. So tomorrow morning 5 o clock I'm installing it. Got the combiner box. (better be safe) So at 10 past 5 I should be up and running again Just a thought. I told my wife we must run this system like Eskom ran their power grid in the 80's and early 90's otherwise we to will be having load shedding on our own system. My next step now is to save up for lithium batteries. Will have to start with either the 2.4 or the 3.5, but I think the 3.5 will be cheaper in the long run. Thank you again and have a great weekend
October 30, 20205 yr Author PS. https://lithiumbatteriessa.co.za/collections/built-units That's second life batteries. They were used in Teslas and Chevvy volts etc... not good enough for Ev's but according to them still ok for home use.
October 30, 20205 yr Bian Also sell new cells. I bought a complete build 6kw battery from Bian 3 months ago. Most days i dont even use any eskom power I have 12 330w panels I run 3 fridges, 2 Tvs, computers and al the other stuff the koi pond pumps as well as the tumble dryer and iron on a 2,4kw mecer inverter, not all at the same time but that is currently how me set up is while i am still renting. I believe his batteries are very good.
October 31, 20205 yr Author 16 hours ago, Krokkedil said: Bian Also sell new cells. Hi. Sorry, I can't find "Bian" anywhere on the internet
October 31, 20205 yr 58 minutes ago, Warlok said: Hi. Sorry, I can't find "Bian" anywhere on the internet I think he is the person behind LithiumBatteriesSA...
October 31, 20205 yr 58 minutes ago, Warlok said: Finally got all up and running and this happens.......... 😭😭😭😭😭
October 31, 20205 yr Author Thanks, I'll check them out. On the plus side, we need the rain more than power
November 1, 20205 yr Morning. Yes Bian is the owner of Lithuim batteries SA. He has 2nd life and new cells as well as all the stuff you will need to build your own battery or a completely build battery.
