David27 Posted January 24, 2021 Posted January 24, 2021 Good morning Guys, I am about to install a Victron Multiplus ii 5Kva - 48V (Clients Choice) and 2x Pylontech Lithium-ion Batteries 2.4. I have never before installed a Victron, (Pylontech Batteries are compatible) So is there any welcome information, advise and some instruction in doing this installation...?? Is there any certain setting required for the Pylontech batteries..? and the inverter..? And any other gadgets required to run the system smoothly. Is it necessary to install a Change Over switch, Surge Protection Etc.? Or any other valuable information will be highly appreciated. This system will be used solely for Load Shedding purposes, 2x A/C Units, Server, LED Lights x6, 4x Desk Top Computers, and CCTV Cameras. Will this system be competent ( Sufficient) to runs all of this during load shedding, 3 hours...? Thank you. Regards David. Quote
P1000 Posted February 11, 2021 Posted February 11, 2021 From the little I know - victron(or their local distro) will not honor the warranty with that configuration - you need 4 of the 2400 pylontechs to deliver peak demand. https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom Quote
Tariq Posted February 11, 2021 Posted February 11, 2021 the Victron is much more involved than an Axpert, i had to get my dealer to do the commissioning. Quote
