Helukable 6mm2
Hi guy I needs some help I just want to confirm if this is the correct cable. I have purchased 6mm2 Helukable but there no markings say helukable and on the cable is 4mm2 and say Shanghai Youngin is this correct thanks.
3 minutes ago, Achmat said:
I don't think that's the correct cable.
Just checked my cable roll. Sorry for the bad label pic.
@Achmat thanks appreciated rellay helps
10 hours ago, Richard Mackay said:
Identifying cable sizes can be confusing, especially when the info isn't printed on the cable!
What I have found useful to check on cable sizes is to use bootlace ferrules to check this.
https://online-electrical.co.za/collections/bootlace-ferrules
That's a great tip, but you still don't know the composition of the metal and where it's from. Quality standards for the past 30 years or so ensure that a cable manufacturer should be able to trace it right back to the mine where the copper ore was unearthed.
I think that this is easily prevented by only buying cable that is properly marked and from a reputable source.
