Solar Collector Circulation pump
Good day Guys,
I have a client that has a solar panel (Collector) connected to his Geyser, with a controller and circulation pump.
He would like the circulation pump to run during a Power Outage (Load Shedding) from the back up Inverter, and obviously NOT the geyser element. Pump Only..
Is there anyone that can give me some advise as to how connect this this up, using perhaps a Relay...???
Is the pump A/C or DC? Most DC pumps run from a battery and will still pump during load shedding provided the pump is good. Some of the DC pumps are even solar connected to charge the battery when A/C is off.
What controller is it using , geserwize?
I've got this. Geyserwise controlling a 12V pump, with 10W solar + battery backup
It is an AC Pump 220V. so it must be switched by the Inverter, via the controller, only activating the circulation pump, when the temperature in the collector reaches a certain degree.
Why don't you just move the controller + pump to the essential side?
Probably because the AC pump draws power via the controller, which also powers the element? (Guessing here). If correct he's going to have to find a way to split the power to the pump. Perhaps change the controller to the essential side by running a new cable for it and use the old cable to power the element. Then have the controller activate a contactor for the element which now draws power from the non-essential. Or switch the pump to 12v if the controller allows.
Edited by Speedster
Yes you are correct. that is exactly what I should do, Thank you. I also got the the advise from Pierre.
  • 2 years later...
If it is a Geyserwise system, I would have thought it provided the option of 2 separate power inputs; one for the pump and control panel and separate one for powering the heating element. Not splitting the inputs means no circulation during midday  blackouts and no heating by the sun. Wow!
Nevinvert som my probleem pragtig op
Ek het 'n solar split unit saam met my 150lt geyser.  Ek wil weet hoe, indien moontlik  ek die probe, die screen en die circulation pump kan koppel op my inverter?
Die gebeur nou met beurtkrag van 10 vm tot 2 nm dat my geyser se temperatuur slegs 45 grade Celcius bereik. Met geen beurtkrag gedurende die dag bereik ek 'n temperatuur van 52 grade Celsius.
Sal waardeer as iemand kan help?
Kan ek my selnommer hier noem?
Dankie by voorbaat
On 2021/01/31 at 11:24 AM, David27 said:
Good day Guys,
Its very easy (I assume your client is using an AC circulation pump) :
1.  Use a transfer switch to render AC power to the Geyser either from the Mains (Eskom) or the inverter backup system
2.  Have a Geyserwise Max installed.
3.  During load shedding I transfer the power supply with the transfer switch to the Inverter backup and ensure that on the Geyserwise Max the element is not selected at all.
For this reason, I do not use the program timer to switch the element on.
4,  The alternative is to install a DC circulation pump with a 10w solar (PV) panel and 12v battery - this will eliminate 1. and 3. above. This is what I'm going to do next,
