Must inverters
I have a 5KW Must PV1800 VHM Series Inverter spec sheet
Currently its only used as a battery backup with a Pylontech battery pack and working well. The settings were a bit fiddly with the LiFo battery as it cant communicate with the battery pack otherwise its working well. I hope to add a few panels soon and test the hybrid function
  • 1 year later...
Hello...I have the same inverter. What settings are you using for Li ? I think there may be typing error on Bulk vs float.
