March 7, 20215 yr Hi Gents, just got my first installation done. 10x445w Mono panels 5kw Sunsynk inverter 2x3000c Pylontechs batteries Custom made IP65 battery/inverter cabinet with space for 2 more Pylontechs
March 7, 20215 yr Author Brand new to this so got a local installer to supply and install but would love any advice.
March 9, 20215 yr Author Would like some advice on the best System Mode settings... My thinking is that I set all to discharge to 25% then monitor how long the batteries last, then I can check when I need to get grid to charge the batteries until sunrise... Any thoughts would be appreciated! Thanks
March 10, 20215 yr 7 hours ago, Leigh said: Would like some advice on the best System Mode settings... My thinking is that I set all to discharge to 25% then monitor how long the batteries last, then I can check when I need to get grid to charge the batteries until sunrise... Any thoughts would be appreciated! Thanks I would only use grid charge if load shedding is expected and there has been overcast conditions causing the batteries to not fully charge. I would also only set the grid charge to 50% as it would be enough to see me through the load shedding slot.
March 10, 20215 yr 49 minutes ago, Achmat said: I would only use grid charge if load shedding is expected and there has been overcast conditions causing the batteries to not fully charge. I would also only set the grid charge to 50% as it would be enough to see me through the load shedding slot. Agree with Achmat, i have a similar setup as you and I've hardly had to use the grid to charge the batteries, only in times of loadshedding... I also discharge my batteries down to 25% across the board..
March 10, 20215 yr Author 12 hours ago, Iiceman said: Agree with Achmat, i have a similar setup as you and I've hardly had to use the grid to charge the batteries, only in times of loadshedding... I also discharge my batteries down to 25% across the board.. Actually a good idea... I will also charge my system modes to all 25%. Thanks
