April 13, 20215 yr Is it possible to upgrade the firmware on a Mecer SOL-I-AX-5M so that I can use Pylontech batteries. The inverter was made in November 2017. Not sure of the serial number as it is hidden behind the adjoining panel. And if so, can you explain in simple terms? Regards Paul
April 14, 20215 yr 11 hours ago, Paulbloggs said: Is it possible to upgrade the firmware on a Mecer SOL-I-AX-5M so that I can use Pylontech batteries. Yes. This model has no removable display, so you can't get use a cable between the inverter and the battery BMS. You could however use a different cable from the BMS to a Raspberry Pi running ICC. That will enable ICC to control switching to and from utility at precise SOC values. It would also be helpful to update the firmware to the appropriate LFP patched firmware for your model. 11 hours ago, Paulbloggs said: The inverter was made in November 2017. Unfortunately, that's in the date range where it could still be a PF0.8 model (4kW), or a PF1 model (5kW). Check your U1 data page to find your current firmware version, that will determine what patched firmware version you need. Check the AEVA PIP-5048 topic for more info: https://forums.aeva.asn.au/viewtopic.php?p=53691#p53691 11 hours ago, Paulbloggs said:
March 29, 20242 yr Hallo Coulomb I noticed you to be quite an expert on firmware updates, and was hoping you can assist me. I have a Mecer, SOL-I-AX8M2 inverter with the following firmware data, and would like to know if more recent firmware updates are available, and where to find them. Thanks for your help.
March 30, 20242 yr 15 hours ago, Janosh said: would like to know if more recent firmware updates are available, The latest 81.xx is 81.07, available here. Unfortunately, it's 6 months old and doesn't support SoC for selected settings. For whatever reason, colour display updates are rather rare, and I don't have any 32.xx firmware updates at all. I've never seen an update for U3 (WiFi?). Quote and where to find them. It's easiest to post with your present versions, just as you did. If I'm about, I'll look up my collection, find the latest version I have, and post either a link or an attachment with it. What a service 😎. Edited March 30, 20242 yr by Coulomb
March 30, 20242 yr 9 hours ago, Coulomb said: The latest 81.xx is 81.07, available here. Unfortunately, it's 6 months old and doesn't support SoC for selected settings. For whatever reason, colour display updates are rather rare, and I don't have any 32.xx firmware updates at all. I've never seen an update for U3 (WiFi?). It's easiest to post with your present versions, just as you did. If I'm about, I'll look up my collection, find the latest version I have, and post either a link or an attachment with it. What a service 😎. Thanks so much for your response.
July 24, 20242 yr On 2024/07/23 at 3:10 AM, Travjs said: How to manualy clear error 51 code on a Meccer 5k 48volt inverter. Fault code 51 is caused by various hardware faults. If you are handy with electronics, there are at least 4 links to people solving fault code 51 here. Otherwise, you will have to get the inverter repaired. There is no way to clear the fault codes like soft trouble codes in a car.
