July 26, 20215 yr On 2021/04/16 at 7:49 PM, Buyeye said: Hi @Koppies I have the same inverter connected to 16 360 watt panels. Connected as 2 parralel strings of 8. The Installer said 2 strings of 9 would be fine but I ran out funds at 16 panels. If you haven't bought the batteries I would suggest skipping the lead acid batteries. The inverter supports dyness lithium batteries. You can get 2 for the same price and usable capacity. Hi @ Buyeye You dont have a problem with too much current going into the inverter from the panels. Max is 18 amps. I want to do the same setup as you 2S2P but I have 16 - 370W panels that ISC is 11.39.
July 26, 20215 yr 16 x 370 = 5920 which is within the 6000 watt pv input limit, check the sticker on the side it also says 40 A ac input. It seems they compensated for the 93% efficiency by allowing higher inputs than the outputs. I've started hearing a beeping when overload time is finished. To answer your question you should not have a problem but I tell everyone the same thing that at R19k the deye/sunsynk on the powerforum store is a much better inverter with better efficiency and 2 mppt's. It's something you want to spend a little extra on to avoid regrets later. Edited July 26, 20215 yr by Buyeye
July 27, 20215 yr On 2021/04/16 at 7:49 PM, Buyeye said: Hi @Koppies I have the same inverter connected to 16 360 watt panels. Connected as 2 parralel strings of 8. The Installer said 2 strings of 9 would be fine but I ran out funds at 16 panels. If you haven't bought the batteries I would suggest skipping the lead acid batteries. The inverter supports dyness lithium batteries. You can get 2 for the same price and usable capacity. @Buyeye. What is the ISC rating of your panels? I would like to do the same with my panels 2 parallel strings of 8 but Isc is 11.39A and the max panel PV amps is 18 on the SPF5000ES
July 27, 20215 yr 1 hour ago, ccitaly said: @Buyeye. What is the ISC rating of your panels? I would like to do the same with my panels 2 parallel strings of 8 but Isc is 11.39A and the max panel PV amps is 18 on the SPF5000ES @ccitalyI'm struggling to find info on 360 watt panels it seems everyone sells higher powered ones now. From memory they are 9A imp which seems my timing was just right since you can't get those anymore. You should be OK since mppt's are good at limiting current as long as you are within the voltage specs which you are. Your 8s2p is exactly the same as mine but you have better panels but you won't be losing any production since total of your panels is still within 6000 watts. Edited July 27, 20215 yr by Buyeye
July 27, 20215 yr 6 minutes ago, Buyeye said: @ccitalyI'm struggling to find info on 360 watt panels it seems everyone sells higher powered ones now. From memory they are 9A imp which seems my timing was just right since you can't get those anymore. You should be OK since mppt's are good at limiting current as long as you are within the voltage specs which you are. Your 8s2p is exactly the same as mine but you have better panels but you won't be losing any production since total of your panels is still within 6000 watts. @Buyeye, Its unlikely that I would see over 20amps but I dont want to blow a new inverter, also what are you using for a PV combiner box or PV protection?
July 27, 20215 yr 11 minutes ago, ccitaly said: @Buyeye, Its unlikely that I would see over 20amps but I dont want to blow a new inverter, also what are you using for a PV combiner box or PV protection? The one on the far right is a battery fuse but I'm not using it since the powerbox comes with it's own breaker. I might use it if I get a second powerbox to parallel. Then I would need a busbar to the 2 powerbox then connect the cables from the busbar to the fuse. Edited July 27, 20215 yr by Buyeye
