Axpert 5kVA Inverter, Pylontech US3000C Battery & Solpiplog vs ICC Software
Dear fellow Powerforum Members,
This is a copy of a letter (with some omissions) I've sent to the powerstore and would like it if someone could assist me further?
(esp. with the use of Solpiplog with the Axpert clone & the Pylon US3000C battery.
Good day,
I’m planning to purchase the Pylontech US3000C Battery from the Powerstore.
After this upgrade I will purchase another 2x415w Canadian Solar panels for a total of 2.49kw and another
US3000C battery (as savings permit).
Will the "Pylon Communication Cable for ICC & New Pylon US3000C" cable work with the Axpert clone inverter?
Just would like to know if the cable would work and give accurate readings if I use a raspberry pi and Solpiplog?
I can use node red to change modes on the inverter via mqtt, but as my AGM batteries are shot (20min @500w until
50% DOD) I’m just using them as a buffer on cloudy days.
I’ve seen the “Inverter control center module kit”(+-R5500.00), but can not afford it at the moment before the
upgrades as it will break the bank.
I'm purchasing the battery 1 June 2021.
Thank you.
What model?
Solpiplog will give you the readings that the Axpert inverter "thinks" the voltage is depending on the firmware. ICC is something completely diffrent
