New Solar Installation
I have just completed my solar setup, after several months of planning and purchasing, and I must say, I am very happy with the results!
My system:
  • 1x Axpert 7,2kW Inverter
  • 14x Canadian Solar 435W panels
  • 2x US3000C batteries
  • 1x Raspberry Pi running ICC
This includes all of the relevant protection boxes etc.
I have spent the past week completing the installation, and now that all of the hardware is in, the tweaking of all of the settings and timing etc. can begin!
A nice surprise being that the unit seems to work as a "semi-hybrid". While in grid mode, it is able to make use of PV to supplement loads, but it isn't a complete hybrid, in that it only makes use of batteries and solar when in "solar mode"
I have been running off-grid since Saturday morning and couldn't be happier! I will need to add another battery at a later stage, as I'm presently not making full benefit of the available PV, despite running my pool pump and geysers during the course of the day. The current 2 batteries just gets me through the night, but we are being mindful of what equipment we are using after hours - an additional battery would really help here - will need to first wait for a few more pay days (don't want my wife to kill me!)
An interesting problem that I don't know how to solve - any input would be appreciated!
In my main, I have 3x Earth Leakage units, which supply the various plugs in the house. When I initially installed my system, I had no problems with my earth leakages, running on either mains or battery. On Saturday morning, however, I noticed that the fridge was off. Upon investigating, I realised 1 of the 3 earth leakages had tripped. When I attempted to reset it, it wouldn't reset. I switched off the downstream breakers, so that there would be no load, and still it wouldn't reset.
However, when the inverter changed to battery / solar operation, there was no issue resetting the EL. Any idea what would cause this? Faulty EL? What I find strange is that it worked previously, and the other 2x EL don't have any issues, so it doesn't make sense to me.
My system:
Very cool setup!! Well played
This is probably where you will need an electrician, because they usually have the test kit necessary to test the sensitivity of the RCD / EL. Alternatively, you could simply swop it and see if it makes a difference, could be cheaper.
Yeah, that's my plan. I'm going to swop the other EL with the "faulty" one and see if the result is the same.
I swapped the EL around last night, and frustratingly, the problem persisted. I then measured the different circuits using a milli-amp meter to determine if there was any major current leak (I initially thought it may be the leakage current from the surge arrestors that was causing the problem) - there was minimal leakage current; certainly not enough to trip the earth leakage.
After a fair amount of testing and confusion, I decided to ring out the neutral circuit to check for any continuity issues that may be cause a ground loop or similar - turns out this was the problem. There is a bare earth cable in my DB, and it was making contact with part of the neutral bar, in an obscure position behind some other wires. As soon as I moved this earth cable, the loop was broken and I could reset the earth leakage - very frustrating, but glad I found it!
