ICC Pylontech Cable
Hi all i am looking for cable that  i can use to connect Pylontech UP2500 to Raspberry PI. Anyone have one they are willing to get rid of for a bargain?
If the cable for UP2500 is the same as for the US3000 you could make up your own cable for about R350. You will need a RS232 serial to USB converter (takealot)and a RJ11 to RS232 cable. The pin outs are quite straight forward and is also somewhere on this forum.
15 minutes ago, CM21 said:
I already had one made but i have noticed some information from the BMS is not being displayed by ICC software.
The cable might be ok, I think it will either work or won’t work at all, it could be a wrong settings like “type of inverter”
Its the battery where i am not getting all the information from. The inverter is very much okay and i am able to get the data from the inverter. I am not able to see how much is remaining to reach 20%, how long it will take to charge the battery to full, even individual cell temperatures e.t.c.
