Pylontech SOC different
Look up how to balance the batteries first. There videos on youtube that show how to balance the pylontechs.
It involves turning them off, disconnect from inverter. Turn batteries on while they all connected together still. They will start balancing each other. Then when you done connect all back up.
Since you do have 2 at 100%, it will be faster to charge the 42% battery to 100%, then balance them again for good measure.
That said, if the problem happens again, then there is a problem that you could call one is faulty.
