February 7, 20224 yr I’ve got a mecer/mustek 5kva invertes with batteries. when power goes out, it dont seem to kick over to battery quick enough, resulting in all my computers being rebooted. Is there a setting to fix this? I should add that the inverter is running at about 80% load Edited February 7, 20224 yr by Zkrige
February 8, 20224 yr Have you tried AC input range (setting 03) on UPS? In this mode, some semiconductors work in parallel with the relay to halve the transfer time from 20 ms to 10 ms.
February 8, 20224 yr 6 hours ago, Coulomb said: Have you tried AC input range (setting 03) on UPS? In this mode, some semiconductors work in parallel with the relay to halve the transfer time from 20 ms to 10 ms. Well, I just learned something. Otherwise I could not make any sense of that setting. I have no major problem with switch over other than a short flicker of the lights. One fluorescence tube with an electronic starter (not an electronic ballast) shuts down. I try it too. W'ill see.
