Seeking info on EVO LiFePo4 batteries
My installer has recommended ECO v5.7 LiFePo4 batteries for my solar installation, but I've never heard of these and am unable to find any info on them. Has anyone dealt with them before and have any experience / info on them? I've searched online and not found anything, which makes me skeptical.
My installer provided a spec sheet but I can't find a way to upload a PDF, so I'm unable to share it. Any info would be really appreciated.
Is the brand maybe not "ECCO"? I have seen that brand commonly sold at the Chinese shops and don't think, the quality will be any good. Ask your installer to provide a picture of the battery and a link to the manufacturer website.
Nice looking battery - suspiciously similar to Hubble AM2 (see images below)
However, the spec sheet seems a bit amateurish: they state elevation > 4000m.  Presumably they mean < 4000m.
Is the enclosure really aluminium?
Looks very much like a no-name here-today-gone-tomorrow setup.  No footprint on Google, no address or company details on the spec sheet.
Who will you contact in 9 years for a warranty issue?
I would steer clear.
From Hubble AM2 manual:
From EVO manual:
On 2022/03/02 at 3:26 PM, sjm2 said:
ECO v5.7 LiFePo4
BTW given the identical box and voltages to the AM2, it is very likely that they are also 13 cell NMC rather than 15 or 16 cell LiFePo4 batteries.
8 hours ago, sjm2 said:
It's definitely Evo. Here's a photo of it as well as the specs
The battery look proper, never heard of it but if the price is good, go for it and write a review. Not so long ago, some of these 1C battery brands were also unknown and they still have a long way to prove them selves too.
41 minutes ago, PowerUser said:
You need to find out if the BMS of the battery will talk to your chosen inverter.
Installer says it will. He says it works better with Sunsynk inverters as it doesn't need a Riot
In the EVO batteries, the BMS has to provide the communication with the inverter. But those batteries are definitely not on the SunSynk compatibility list. Your installer has to prove they can talk over CAN bus to each other.
If he says that then it means he must have tested it or did an installation using it sunsynk. After all, the battery looks similar to Hubble, my guess is that the internals and BMS might also be the same. Since there is no info on this battery, you will be the one confirm if it works and share with the forum.
From EVO manual:
Hubble removed the display screen and forgot to correct the numbering. they just skipped number 5 and went straight to 6
  • 6 months later...
Hi guys, new EVO is launching shortly. Previous version was manufactured in the same factory as Hubble. Works with sunsynk can to can protocol 0, Deye can to can protocol 00, growatt no problems can to BMS/ CAN protocol 52 on 5.7kw.
the new version is 1.5C rated. Max charge and discharge 150A. 5.7kw usable capacity and Lithium Iron not Ion which is better suited than lithium ion for the application.
Wall mount is simple and effective for installation. Now also comes with a colour touch screen to view cells SOH etc
  • 6 months later...
Hi, i know this is late, but could i maybe contact you to discuss communication with these inverters with a growatt inverter. my email is [email protected]
thank you
