GeorgeS Posted March 3, 2022 Share Posted March 3, 2022 Hi. Can a single 3 phase inverter be powered by 2 phases without causing damage to the inverter? Quote Link to comment Share on other sites More sharing options...
JpPaulKruger Posted March 9, 2022 Share Posted March 9, 2022 On 2022/03/04 at 12:04 AM, GeorgeS said: Hi. Can a single 3 phase inverter be powered by 2 phases without causing damage to the inverter? I’ve asked similar questions about 3 phase setups and yet to find answers. Quote Link to comment Share on other sites More sharing options...
Wasim Posted March 10, 2022 Share Posted March 10, 2022 yes, of course. The inverter technology primarily rectified the AC into DC and then converts DC TO DC using buck or boost scheme and finally inverts the DC back into AC. There its safe, to suppy a 3 phase inverter with single phase or double phase or even supply with the required DC voltage, the inverter firstly it rectifies it into DC. If inverter supplied by required DC voltage for example 420DCV, the rectifier directly passes the DCV to bulk capacitor. hope ...I have cleared the point. Quote Link to comment Share on other sites More sharing options...
P1000 Posted March 10, 2022 Share Posted March 10, 2022 3 hours ago, Wasim said: yes, of course. The inverter technology primarily rectified the AC into DC and then converts DC TO DC using buck or boost scheme and finally inverts the DC back into AC. There its safe, to suppy a 3 phase inverter with single phase or double phase or even supply with the required DC voltage, the inverter firstly it rectifies it into DC. If inverter supplied by required DC voltage for example 420DCV, the rectifier directly passes the DCV to bulk capacitor. hope ...I have cleared the point. While you are correct in principle, unless you know how the inverter will handle this situation, your advice might be leading the OP down the wrong path. The problem is, to the inverter this situation looks like a grid fault, and it will most likely island itself. Quote Link to comment Share on other sites More sharing options...
GeorgeS Posted March 25, 2022 Author Share Posted March 25, 2022 Thanks for the input guys and sorry for taking so long to come back to the question I first had. The answer is that you can use it in 2 phase but the inverter alarms go off and it gives you some error codes which includes the W03 error code. The manual states that when getting this error it means a grid phase error and to use 0/120/240 which I did and it works. I have tested the inverter in UPS mode but am getting strange readings when I change it to when I want to feed to my local grid. That said I don't have enough solar to fully test this. I hope this will be of help to someone with the same problems I had. I am still impatiently waiting on the municipality to install my 3 phase meter....2023 anyone? Quote Link to comment Share on other sites More sharing options...
Songtoan031 Posted August 16, 2022 Share Posted August 16, 2022 Thank you I will try this way. Has anyone encountered this and has a solution for it? Quote Link to comment Share on other sites More sharing options...
kevinmaa Posted January 16 Share Posted January 16 On 2022/03/25 at 8:10 PM, GeorgeS said: Thanks for the input guys and sorry for taking so long to come back to the question I first had. The answer is that you can use it in 2 phase but the inverter alarms go off and it gives you some error codes which includes the W03 error code. The manual states that when getting this error it means a grid phase error and to use 0/120/240 which I did and it works. I have tested the inverter in UPS mode but am getting strange readings when I change it to when I want to feed to my local grid. That said I don't have enough solar to fully test this. I hope this will be of help to someone with the same problems I had. I am still impatiently waiting on the municipality to install my 3 phase meter....2023 anyone? My inverter was working fine until my one phase from Eskom broke. Municipality came and bridged some of the phases and now i get the W03 error and inverter does not recognise power coming from the grid Quote Link to comment Share on other sites More sharing options...
