March 18, 20224 yr Greetings, What is the approximate power consumption of a gearless, machine room-less (MRL) 10 persons 800 kg passenger elevator e.g Schindler 3300 MRL traction elevator? I need to hook one up to 3-phase solar inverter and I can't find this information on the Internet. Any leads would be greatly appreciated.
March 18, 20224 yr So for just moving 800kg at 1.5m/s you need around 12kW. But the problem is more complex than that because it probably has counter-weights and other losses as well (like friction and motor efficiency etc.). With counter-weights it could mean that you only require half that power, but you also need to be able to accelerate. I think you should contact the manufacturer...
March 18, 20224 yr Author 22 minutes ago, P1000 said: So for just moving 800kg at 1.5m/s you need around 12kW Aha. I have to refresh my knowledge of Newtonian or classical mechanics F = m x A etc. 26 minutes ago, P1000 said: probably has counter-weights Yes, it does have counterweights. That I'm 100% certain. 26 minutes ago, P1000 said: I think you should contact the manufacturer Looks like it considering it probably has a regenerative drive that sends power back into the building when descending.
March 21, 20224 yr According to Schindler USA, 5,7kw. 34 amp starting current, 26 amp nominal Power Calculator : Schindler USA & Canada (schindler3300na.com)
January 23, 20233 yr Author On 2022/03/21 at 7:31 PM, Mauritius B said: According to Schindler USA, 5,7kw. 34 amp starting current, 26 amp nominal I guess 26A FLA is at 240Vac split phase (USA/Canada). For 415Vac three-phase, FLA for a 5.7kW motor will be in the order of 10-15A depending on the PF.
January 27, 20233 yr Author Asia Fuji - Small machine room passenger elevator parameters. Capacity (Kg) Person Speed (m/s) Entrance(mm) Clear car dimension (mm) Caroutstide dimension (mm) Clear hoistway dimension (mm) Machine room dimension (mm) Pit depth (mm) Overhead Height (mm) Pit reaction load (KN) Machine room reaction load(KN) Rated power (KW) Power supply capacity Lead-in wire Q NO. V OP CWXCD SWXSD HWXHD MWXMDXMH PD OH R1 R2 R3 R4 KW KVA MM2 450 6 1.0 700 1200x1100 1252x1266 1800x1800 1800x1800x2200 1500 4400 50 40 20 8 3 3.6 4 1.5 1600 4500 4.8 5.8 4 630 8 1.0 800 1400x1100 1452x1266 2000x1800 2000x1800x2200 1500 4400 68 54 24 10 4.3 5.2 4 1.5 1600 4500 6.8 8.2 6 800 10 1.0 800 1400x1350 1452x1516 2000x2050 2000x2050x2200 1500 4400 76 60 28 12 5.4 6.5 6 1.5 1600 4500 8.6 10.3 6 1.75 1700 4600 9.6 11.5 6 2.0 1800 4700 11 13.2 6 1000 13 1.0 900 1600x1450 1652x1616 2200x2200 2200x2200x2200 1500 4400 90 72 32 15 6.4 7.7 6 1.5 1600 4500 10.7 12.8 6 1.75 1700 4600 11.7 14 6 2.0 1800 4700 13.4 16.1 10 2.5 2000 4900 17 20.4 10 4.0 3800 5900 27.7 31.5 10 1250 16 1.0 1000 1800x1550 1852x1716 2400x2300 2400x2300x2200 1500 4400 105 80 36 18 8.5 10.2 6 1.5 1600 4500 13.5 6.2 10 1.75 1700 4600 14.8 7.8 10 2.0 1800 4700 17 20.4 10 2.5 2000 4900 22 26.4 10 4.0 3800 5900 34.6 39.6 10 1350 18 1.0 1100 1900x1600 1952x1766 2500x2300 2500x2300x2200 1500 4400 115 90 40 20 9.3 11.2 6 1.5 1600 4500 14.9 17.9 10 1.75 1700 4600 16.3 19.6 10 2.0 1800 4700 18.7 22.4 10 2.5 2000 4900 23.4 28.1 10 4.0 3800 5900 36.8 44.2 10 1600 21 1.0 1200 2000x1700 2052x1866 2600x2400 2600x2400x2200 1500 4400 136 105 48 26 11 13.2 6 1.5 1600 4500 17.5 21 10 1.75 1700 4600 19 22.8 10 2.0 1800 4700 22 26.4 10 2.5 2000 4900 27.5 33 10 4.0 3800 5900 34.2 41 10
