Pylontech 300OC
Hi there gents
I have recently bought 8 Pylontech US3000C batteries and wanted to confirm that I just have to leave all of the dip switches  at 0000? The manual is a little hard to follow.
Thanks for the help
Dip switch on master battery only needs to be 0001
Not in my case. All dip switches off  even the master as in the foto provided.I suppose it varies between the setups.
Edited by Piper
As I understand it the first dip switch (1) is the baud rate and the second (2) is the master/slave. The manual states that the master dip switch can be left on 0. I have no clue if changing the baud rate changes anything?
