March 19, 20224 yr Manual lists 14 mm drill bit size, but found that is too large a diameter for the supplied rawl bolts, what size have you guys used out there
March 21, 20224 yr On 2022/03/19 at 10:48 PM, Tariq said: Manual lists 14 mm drill bit size, but found that is too large a diameter for the supplied rawl bolts, what size have you guys used out there What size are the bolts? For 4.5 to 5mm screws I use 6mm drill bit and plugs to fix my inverters to the wall. First drill with 5.5mm and then widen with 6mm to prevent the hole to get too big.
