Mecer 2400va not inverting
Good day all
Recently purchased a brand new Mecer 2400va invertor, and been set up complete with 2 x 12v batteries
As of today Eskom went off and invertor switched to battery mode however the load, a basic home office setup didnt come on
Prior to this it had worked
Panel shows output of 224, no error or fault messages
Tried pressing reset switch to no change
Please help, thanks
thanks, i have pressed that countless times to no change, also the output reads as per screen however when on battery nothing is powered at all
hope that makes sense
I would remove the lead connected in the sockets feeding the loads and connect only a cell charger in the one socket. Check if the charger is working. Do this when the grid is on as well as when you switch off the plug feeding the unit.
See if charger works both ways to charge phone.
17 hours ago, Scorp007 said:
Thank you, i used a desk lamp and it powers up when invertor is connected to grid and as soon as grid powers off it switches off although the panel still shows output
4 hours ago, LyricalYC said:
The guys that know the circuit for your inverter might give their ideas why panel is on but no output.
As it is new have it checked out and repaired instead of fiddling around and battling with a faulty unit.
Presuming that it's a genuine Mecer (and that the Mecer is a genuine Voltronic UPS, or some other reasonable brand), yes. You presumably paid more for the warranty support (compared to a clone direct from China, say).
I believe that Mecer have decent repair centres too, for when it's out of warranty.
The worst clone we were talking about some time ago with less than 15 settings packed up with some smoke within a few weeks and he managed to have it repaired by the seller. It has been running OK now for about 4 months. This does prove when buying from a seller with a workshop does help when venturing into the clone mine field.
The picture in this case seems like a Mecer sold as a combo unit.
thank you all, it is a genuine Mecer unit, challenge it will cost nearly same to ship it back to supplier as unit was sent out of country
i have however concluded the breaker is faulty, non responsive and would like to replace it.
where can i source an L2 series 2 ups 15a breaker, i seem to be landing on 20A or 50A ones however want to try replace with exact one on faulty unit (see pictures)
either an online store or physical store in Joburg West area will do
Thank you
Thank you
https://za.rs-online.com/web/p/thermal-breakers/3445333
  • 7 months later...
Hi there have the same unit and it is completely dead, have connected the batteries and plugged it in but when i press the power on button nothing happens??
Have you checked that the overload button on the left is not in a tripped state. Press it before switching on.
On 2022/04/26 at 8:50 AM, LyricalYC said:
thank you
Hi I have exact same inverter with the same problem just wanted to find out after changing than breaker was the issue resolved
  • 4 months later...
On 2022/04/21 at 5:01 PM, chrisc said:
There is a circuit-breaker at the rear.  Push it in
Check the output with a meter
Hi, is the circuit breaker button like one in a DB for example? I have the Mercer 1200VA inverter. The battery only last an hour if we are lucky. Only 1 tv with the DSTV connected. Is the CB Button suppose to be clicking or hard to press in. At the moment nothing happens when I press it. How do you check the output (what rype of meter)? We purchased the Inverter in December 2022. Thank you
Hey guys,
I have a Mecer Lobo 1200va inverter.
So everything is connected fine with battery and also plugged into the wall socket the unit is dead.
Screen and warning lights does not come on and nothing happens.
When I play with the power button and push it a few times the screen sometimes come on but like for a split second, flashes and off again.
Any ideas on what could be the problem?
It sounds like the internal power supply is not working.
If it's several years old, it might be possible to replace a few capacitors and get it going.
fine with battery
How confident are you of the battery's health? Can you put a multimeter on it and report the voltage before and after switching on? Especially one of the times it comes on a little.
  • 7 months later...
Hi My Mercer 720w inverter charges battery when power switched of it displays a output voltage of 235v (AC) and the Battery displays 100% with orange led on but there is no output voltage on the sockets.I tested the circuit breaker it test  good on continuity(Note this CB is for AC supply incomer not to reset battery output voltage). Note when switching off the supply power there is a click sound from the relays and the machine changes over from standby to inverter mode. with no voltage when measured and the outlet sockets on the unit. What could be possible causes to this if possible a schematic diagram of the circuit would help.
  • 1 year later...
Hi Romeo
Did u hv any luck?
Pls reply to [email protected] or 08333 00 850 if u did.
Kind Regards Simon
