June 19, 20224 yr Good day, Did anyone manage to get the Cloudlink to communicate with Sunsynk 8 Kw Inverter, i am connecting 4 Hubble Batteries 5.5Kw with Sunsynk 8 Kw. according to @HubbleLithium Full monitoring is available for the Sunsynk 8KW & 12KW Inverters currently, I have tried all the settings indicated by Hubble but Inverter still not connected, only Batteries. I have done the following: RJ12 RIOT S port to RJ12 Master Battery. RJ45 Connecting RIOT MUL port to RS485 port on SunSynk. CAN BUS RIOT to CAN Inverter.
June 19, 20224 yr My suggestion is "Return the RIOT and get Solar-Assistant." I never got my RIOT to work. Edited June 19, 20224 yr by system32
July 9, 20224 yr Author UPDATE Thanks to Steve @Powerforum Store and an Engineer from Hubble, my Cloudlink is now connected with full monitoring capability. just minor change in the Inverter Settings.
September 16, 20223 yr @semsem are you able to share how you got this working? I’m having the same issue. So maybe what you did will work for me as well. Thanks.
October 10, 20223 yr @OnewheelerSA This forum post may help in getting RIOT working: https://powerforum.co.za/topic/9858-riot-cloudlink-sunsynk-deye-monitoring/?do=findComment&comment=135896
