July 1, 20224 yr Hi Gents, I have a question and not sure if it has been asked before. Basically I have 2 x US2000B batteries Now I know that the recommended discharge per battery is 25A. Does this then double to 50A for the 2? Also what would happen if an Us3000C is added to the bank? Thanks for your time.
July 1, 20224 yr Yes. Discharge rate is per battery. If you add the 3000C, the max rate will be 37A+25A+25A = 87A
July 1, 20224 yr Author Great! so effectively my Current recommended Discharge is 50A. 1 minute ago, P1000 said: Yes. Discharge rate is per battery. If you add the 3000C, the max rate will be 37A+25A+25A = 87A
July 5, 20224 yr On 2022/07/01 at 11:18 AM, Etiennet said: Great! so effectively my Current recommended Discharge is 50A. I always like to mention the Voltage when taking about A or Ah, as some people assume 220V. 50A x 48V = 2,400W Edited July 5, 20224 yr by system32
