July 24, 20224 yr Hello all I have a 5kw Deye inverter running a 4.8kw dyness battery. There are 2 things it's doing which I need advice on. 1. The battery only charges to 80% . Is there a battery setting or a charge setting that might need to be activated or might need to be changed . Is charge times for ac charge of the battery perhaps? 2. The other issue is that the other night the inverter started using battery power when there was no load shedding. The ac green light was on but the inverter showed eskom was disconnected with a red cross and the battery was draining down to supply the load . Is this a setting too or something more critical ? I'm told it could be that the grid and the inverter are not stabilizing together. Or Is it a wiring issue as it was fine before. It happened just after 12am. Thank you
July 25, 20224 yr Please share images of your Battery Setup (type and charge) screens as well as your Work Mode 1 screen
July 25, 20224 yr Author It's a dyness 4.8kw Connected by bms cable When I click on the Battery info it shows everything as it supposed to. Is this a problem you seen before.or maby a setting?
July 25, 20224 yr 1 hour ago, Millmatt said: It's a dyness 4.8kw Connected by bms cable When I click on the Battery info it shows everything as it supposed to. Is this a problem you seen before.or maby a setting? As requested, share pics of the system work mode screen.
July 25, 20224 yr 3 hours ago, Millmatt said: Which screen is that ? Home screen or the one in battery bms ? Hit the gear/settings icon in the top right corner of the home screen.
July 25, 20224 yr 3 hours ago, Millmatt said: Which screen is that ? Home screen or the one in battery bms ? Click on the red arrow and then you should get the following two screens.
July 25, 20224 yr Author Time of use screen .. Had a feeling it might be activated. Ok . I'll go check.
February 14, 20233 yr The electrician had installed rep 5kw Deye in a parallel line. The AC light on one iinverter is on , and the other one is off. When I plugged the kettle the inverter trips off. Please help
June 7, 20233 yr hello on the systems grid power graph it shows negative bars on the graph. what does that mean?
June 7, 20233 yr 14 minutes ago, werner pelser said: hello on the systems grid power graph it shows negative bars on the graph. what does that mean? Do you have "Solar Sell" or "Selling First" activated? Are you exporting power to the grid? If so, best is to turn that off if you're not registered to sell into the grid, or don't have the right type of meter. Best case, maybe you're just spinning an old disc meter back. Worse case, if you have a prepaid meter, you're possibly accumulating cost as you're giving away power, and alerting the municipality.
