August 3, 20224 yr *Please note I have changed the Topic description Good day All, I'm very new to this. I'm looking for device that will allow me to pull logs. Specifically Amp's. I have seen devices that can give historical logs in kWh but that won't help me. I need to know what is the max Amp's pulled on which day of the week and what hour of the day What is on the market,what are you guys using? Recommendations please Regards Edited August 4, 20224 yr by Shaunj187za
August 3, 20224 yr Although some breakers do give/log some info I would suggest getting an ET112 unit, the logging on that is excellent.
August 3, 20224 yr 4 hours ago, Shaunj187za said: Good day All, I'm very new to this. I'm looking for a mains circut breaker that will allow me to pull logs. Specifically Amp's. I have seen breakers logging kWh but that won't help me. What is on the market,what are you guys using? Regards Like the CBI Astutes?
August 3, 20224 yr 6 minutes ago, PsyWulf said: Like the CBI Astutes? If one opens their APP do the values update within 5sec or is there a longish delay to see the current values?
August 3, 20224 yr 53 minutes ago, Scorp007 said: If one opens their APP do the values update within 5sec or is there a longish delay to see the current values? Seems to be 1-2seconds,i've used these types of breakers to monitor power consumption live as devices are switched on and off
August 3, 20224 yr 42 minutes ago, PsyWulf said: Seems to be 1-2seconds,i've used these types of breakers to monitor power consumption live as devices are switched on and off Thank you. I have found the Sonoff used to be good but after a few updates I feel like dumping the pow2. I would leave home and 45min later when I open the APP it would still show the status before I switched something at home. It would even show the power being used by the item I switched off. While looking at the APP I can switch something or adjust the load of equipment and it would take up to 15 sec to respond. I can view the daily graph and go back to the current power reading and it has still not updated. Newer software is not always better.
August 3, 20224 yr 1 hour ago, Scorp007 said: Thank you. I have found the Sonoff used to be good but after a few updates I feel like dumping the pow2. I would leave home and 45min later when I open the APP it would still show the status before I switched something at home. It would even show the power being used by the item I switched off. While looking at the APP I can switch something or adjust the load of equipment and it would take up to 15 sec to respond. I can view the daily graph and go back to the current power reading and it has still not updated. Newer software is not always better. Haven't noticed the same but then again I only experimented with Ewelink (Sonoff) Found my preference to be Smartlifehome (Tuya) like this
August 3, 20224 yr 4 minutes ago, PsyWulf said: Haven't noticed the same but then again I only experimented with Ewelink (Sonoff) Found my preference to be Smartlifehome (Tuya) like this Thanks for the link to products.
August 3, 20224 yr Author @Riaanh do you currently have the ET112 setup? @PsyWulf the "CBI ASTUTE" does it tell you the max amps achieved ? I really need to know #1 How close & #2 at what time of the day am i close to popping my 60AMP breaker. Edited August 3, 20224 yr by Shaunj187za
August 3, 20224 yr @Shaunj187za correct, yes I do have one installed here by me. ALthough it is not a breaker or Wi-Fi as you actually requested, but in my opinion one of the best (Read most accurate) loggers. I started off by logging to PC, currently just using it to log to the Pi. Data via Serial: Current 0.001 A Voltage 0.1 V Power 0.1 W or var Frequency 0.1Hz PF 0.001 Energies (positive) 0.1 kWh or kvarh Energies (negative) 0.1 kWh or kvarh Run hour meter 0.01 h Sample rate for data is 4096 samples/s @ 50Hz I set my logging for (per second) that operates sufficiently for me with what I need, so all values return every second. R
February 14, 20233 yr Bit of a hijack on this thread, but I'm looking for a clamp-style (CT) power logger so that I can check the peak usage on my 3-phase supply. I don't mind if it is only a single clamp system: with loadshedding, there is ample opportunity to swap between L1, L2 and L3 😀 Since this will be a once-off use to determine my peak loads prior to finalising my PV inverter purchase, it shouldn't break the bank. I don't mind WiFi or BT as I can use either a laptop or Android phone to access the logs. Any suggestions?
