Reputable installer in Pretoria?????
Good morning - I hope someone can assist. I installed a solar system (5kw solar panels, 5kw inverter, 12kn Li batteries) at my house approx. 6 years ago, and the had numerous initial problems caused by installers not knowing what they are doing etc.
I now want to install a load shedding solution at my mom's house (initially 5kw Sunsynk, 3.5ke Pylontech but possible solar panels and increased battery bank later) and need to find a reputable installer in the Pretoria East area who knows what they are doing and whose installation will work perfectly from the start - my mom is in her late 70's and need a totally reliable solution without any drama.
Can anyone recommend a reliable installler - not just a bakkie electrician suddenly jumping on the solar and load shedding bandwagon claiming to be an expert???
Thanks in advance
I would like to assist but I don't support Sunsynk installations. However @Leshenis a very reputable Sunsynk installer/ operator. You quite correct, get it done right the first time...The forum member above will definitely do just that.
If your requirements are for Voltronics/ Axpert/ Kodak I would be able to assist.
Best of luck.
