Panel config confirmation: 8K Deye and 18x 455W panels
Please help.I live in Modjadjiskloof ,limpopo average temp normally between 10 to 35 degree celcius.I have a 8kw Deye invertor with two 5,5kw hubble batteries and 18 x455w mono perc half cell solar panels ,the panels should be two strings, one each side of the pitched roof come to 9 on each side, what is the best way to connect it, I have 3 in a row(paralel) that is 3 rows  of which all 3 rows are in paralel to provide a positive and negative lead to combiner box ( Protection on lightning to earth) Are this a good method to connect
Let's start with what voltage are you seeing on the inverter for PV?
  • Moderator2 changed the title to Panel config confirmation: 8K Deye and 18x 455W panels
