StepbyStep Posted October 10, 2022 Share Posted October 10, 2022 (edited) I've been trying to get my Riot Cloudlink up and running but the inverter & PV info doesn't show. I checked all connections and they're fine. I contacted Hubble Support who suggested upgrading the firmware on my one battery because it was old and that's where the fun starts. The update doesn't go through despite trying the old and new firmware versions. I'm using the cable from Solar Assistant. Are there settings on the SunSynk I should be using while trying this firmware update? Has anyone run into a similar problem? System: 1x Inverter: SunSynk 5.5 KW (M3.3.8.0 / S0.5.1.3 / CE4.2.4 1x Riot Cloudlink: partially online (see pic below) 1x Master Battery: HL210500**** (this is the old one) 1x 2nd Battery: HL220700**** Failed Updates: 1.46: Failed to request MCU upgrade command 2.05: BIN File Error Edited October 10, 2022 by StepbyStep Typing in inverter errors & grammar Quote Link to comment Share on other sites More sharing options...
StepbyStep Posted October 10, 2022 Author Share Posted October 10, 2022 I spoke to a very nice, calm gentleman in Hubble Support. R&D is still working on the Hubble-SunSynk connection. It'll be up and running eventually. My batteries are fine - the Bin code errors I'm getting are basically my battery saying it's running on 1.46 & doesn't want to be updated. Quote Link to comment Share on other sites More sharing options...
DeonBez Posted October 16, 2022 Share Posted October 16, 2022 (edited) This info might be of help https://www.hubblelithium.co.za/sunsynk Edited October 16, 2022 by DeonBez zsde 1 Quote Link to comment Share on other sites More sharing options...
Sidewinder Posted November 29, 2023 Share Posted November 29, 2023 Hi @StepbyStep It's a year+ later, tell us, did you manage to upgrade your old battery? I'm in the same boat, I (also have access to) 3 x AM2's Master - HL2202* F/W - P13S120A-12290-1.50 Shown as 100Ah Slave 1 - HL2106* F/W - P13S120A-12290-1.50 Shown as 50Ah Slave 2 - HLD2209* F/W - P13S100A-12290-4.50 Shown as 100Ah When I try to upgrade Slave 1 (to 2.05), I get the BIN file error. (The assumption here is that the BMS is an older version, and V2.05 is not campatible with it) Can you or anyone else please share 1.46, so I can try and fix the 1/2 capacity battery. Or 1.50/4.50/any other versions, seeing the other 2 batteries are fine with those versions, BMS dependant. Have e-mailed Hubble support twice, first time they closed the ticket without sending the file, the 2nd time, no response. Quote Link to comment Share on other sites More sharing options...
StepbyStep Posted December 2, 2023 Author Share Posted December 2, 2023 Hi @Sidewinder I'll have a look around if we have a copy of 1.46 somewhere but it'll take a couple of days. We didn't upgrade the battery in the end - we think it was remotely done or it was already running on 1.46. Sidewinder 1 Quote Link to comment Share on other sites More sharing options...
Sidewinder Posted December 4, 2023 Share Posted December 4, 2023 @StepbyStep, thanks that would be great. Quote Link to comment Share on other sites More sharing options...
