July 8, 20179 yr Today we are finishing up rewiring of our db . Is there a start up procedure that i need to follow when starting up the inverter for the first time?
July 8, 20179 yr Hi Richyv, The user manual will tell you, but in essence, Batteries on first, after axpert starts, takes quite a few seconds, then switch on Grid, then switch on load lastly. Switch off is the reverse. After Axpert has started up, you can start by adjusting your individual parameter. Hope this helps. Others please feel free to add/amend.
July 9, 20179 yr Author 12 hours ago, Sidewinder said: Hi Richyv, The user manual will tell you, but in essence, Batteries on first, after axpert starts, takes quite a few seconds, then switch on Grid, then switch on load lastly. Switch off is the reverse. After Axpert has started up, you can start by adjusting your individual parameter. Hope this helps. Others please feel free to add/amend. Thanks for the response. Manual basically says once all connections are made turn on the unit. system is online. now just to fine tune
July 9, 20179 yr @Sidewinder is correct , first batts then , my case , panels , inverter switch then load. You don't really ever want to turn off the batts when under heavy load !! Here is a old forum favorite.
July 9, 20179 yr Author 6 hours ago, PaulF007 said: @Sidewinder is correct , first batts then , my case , panels , inverter switch then load. You don't really ever want to turn off the batts when under heavy load !! Here is a old forum favorite. Interesting video that
July 12, 20179 yr And it's suggested that you keep the inverter switched off, bottom right. Connect the batteries > then the solar panels > then eskom > then switch on the inverter.
