Easun axpert max 8kw firmware
  • Replies 180
  • Views 29.1k
  • * Did you update display firmware or main firmware?  * What was the original firmware version?  * What version did you update it to?
  • Hi thanks for the help! Downloaded this link:  https://diysolarforum.com/resources/mpp-solar-8000-max-voltronic-axpert-8000max-lasted-firmware.288/ and on that link it has the display f
  • BritishRacingGreen
    BritishRacingGreen
    Youre  right, but i must add that my own Altera Blaster works with OpenOCD. Its actually a standard FT245(ftdi) frontend with backend cpld. But its vid/pid and ft245 requirement will probably not find
8 minutes ago, Gilberto said:
But how do i download the original firmware from the chip?
Read back, entire chip
after save data readed.
after load data from me, write entire data (erase chip first to write)
Have this error
17 minutes ago, mihaigsm2003 said:
try write, maybe settings error or MCU faulty
When I select the chip there are several GD32F105 like this: GD32F105xx
where can I find the last letters?
Is GD32F105VCT6
But I can’t find that one on the list. What I find is GD32F105VC
but I can’t download or erase also
1 minute ago, mihaigsm2003 said:
Again i ask you, why need to write firmware on display?
After I tried to update the control panel turned black
When you connect the interface to the display for programming, does any LED light up? that is, you have 3.3 volts, at the same time, did you make the settings correctly for that type of microcontroller? Maybe you need to supply voltage to the board, if I remember correctly I also used RST connected to the MCU. Jlink is a little more complex, and I have worked with it a little. This is pinout (this board have STM32F107, but same pinout)IMG_8902.JPG.8be8e48632efbcf587f5174e580ca577.JPG
I am using 3.3v and it does light up the Wi-Fi board.
Connect VTref to 3,3V on board or to Vcc on interface, Check if VCC on interface is 3,3V
Use power from interface becouse reset MCU when do job
Use SWDIO and SWCLK also maybe need reset pin to MCU (see datasheet for GD32F105)
SEGGER J-Link Isolators — SWD Isolator
sucsess! ut it is not in hex file
real original.jflash
I have loaded your file and it write successfully. But the display still does not turn on
Firmware is for offgrid, inverter work? get power?
Now can update with official good firmware via serial cable, don't push DSP button
Edited by mihaigsm2003
U know where I can got official firmware? For easun 8kw off grid
