Easun axpert max 8kw firmware
8 hours ago, Coulomb said:
Could you post a screen dump, please? That photo is extremely hard to read.
I see you found some software; which one?
You seem to be powering the display board, at least the 3.3 V part of it. My guess is that you haven't connected the wires correctly (3.3 V and ground must be correct, so it would be the other two), or you need to try the other protocol. I don't know ARMs at this level. It's possible that it just doesn't know the GD chip.
Can you set the device to an STM32F105, perhaps in the drop down box in the toolbar?
I have set to stm32f105 and still error. I have checked wires
  • Replies 180
  • Views 29.5k
  • * Did you update display firmware or main firmware?  * What was the original firmware version?  * What version did you update it to?
  • Hi thanks for the help! Downloaded this link:  https://diysolarforum.com/resources/mpp-solar-8000-max-voltronic-axpert-8000max-lasted-firmware.288/ and on that link it has the display f
  • BritishRacingGreen
    BritishRacingGreen
    Youre  right, but i must add that my own Altera Blaster works with OpenOCD. Its actually a standard FT245(ftdi) frontend with backend cpld. But its vid/pid and ft245 requirement will probably not find
7 minutes ago, mihaigsm2003 said:
Use GD-Link for GD32, not work with ST-Link, also need aplication for GD32
i programmed GD device with jlink interface
Thanks for the help. Will this one work?
1 hour ago, mihaigsm2003 said:
Pls check first application if ur cpu is 100% compatible with this interface. I programmed stm32f103
My processor is gd32f105
9 minutes ago, mihaigsm2003 said:
supported!
That’s great! Can u help me with the steps? What software I need. This is the 1st time doing this
10 minutes ago, mihaigsm2003 said:
supported!
That's great! Can u help me with the steps in doing this? What software needed? This is 1st doing something like this
This is different MCU, is GD32F305VET6, but, i read firmware wit ST-LINK and Visual ST without any problem, i select STM32F107 and work good. This is display with touch buttons, not work for you, for you i think work firmware for STM32F107, and i have firmware for you.
Can u give me the firmware? Help me with the process?
I have recieved the jlink. How is the wiring to the control panel?
14 minutes ago, Gilberto said:
I think I have entered the chip.
Yes, that actually looks like the start of the bootloader. Well done!
15 minutes ago, Gilberto said:
What now?
Now you find the menu command to read the flash image, and save it to a hex file. Please post that hex file here as an attachment.
Nearby, you will likely find a menu command to read a hex file and program it to the device. But you'll have to carefully set things up before pressing the "burn baby, burn!" button. Also, we have to choose the right hex file for you to burn. I'll have to review your posts to make that decision.
Thanks. I am going to look at it now
I tink its this?
original.hex
