Easun axpert max 8kw firmware
21 hours ago, jovani said:
Do you have guys a firmware for main and lcd that they are compatible?
I would think that any recent main firmware should work with removable display firmware version 12.21. Failing that, you might try the more recent 38.11 (though 38.11 seems to be mainly for VM IVs).
I believe that both of these should work with either display chipset. Since about August 2022, we should not have to worry about display chipset, at least for Axpert MAXs.
  • Replies 180
  • Views 29.1k
  • * Did you update display firmware or main firmware?  * What was the original firmware version?  * What version did you update it to?
  • Hi thanks for the help! Downloaded this link:  https://diysolarforum.com/resources/mpp-solar-8000-max-voltronic-axpert-8000max-lasted-firmware.288/ and on that link it has the display f
  • BritishRacingGreen
    BritishRacingGreen
    Youre  right, but i must add that my own Altera Blaster works with OpenOCD. Its actually a standard FT245(ftdi) frontend with backend cpld. But its vid/pid and ft245 requirement will probably not find
  • 1 year later...
good morning guys and Happy 2025 everyone! I hope you can help me: I have the easun 8kw that you talk about here in the forum, my firmware is 46.05, everything works well for my needs but I would like a more updated firmware to work with the SOC and not with the voltage, what do you suggest to do: I didn't quite understand whether it is sufficient to update the inverter firmware or whether it is also necessary to update the display firmware. If so, where can I find the display firmware version? Could you kindly post the files of both and make a summary of the situation for desperate people like me? :)
You need a  main firmware that handles the QDOP command. 46.05 is way too old for that. The latest is 46.83, available here.
Yes, the display firmware also needs updating.
Wherever you found the U1 version, the U2 version is for the display. Either in monitoring software or on the display itself.
It's probably 12.xx or 122.xx. If so, the latest version is 12.28, available here.
The linked posts should have links to the firmware upload instructions.
thank you! you are very kind, I haven't checked yet but where can I check the version of my display? is better tu update first the display or first the inverter?
Edited by ross68
Like I said above, "Wherever you found the U1 version, the U2 version is for the display." You can just press the down button on the display until you get to a "page" with U2 at the top. Just report the two numbers under that.
Example:
Axpert King Inverter Firmware - Page 14 - Axpert Firmware - Power Forum -  Renewable Energy Discussion
This inverter is running display firmware version 02.83.
is it better to update first the display or first the inverter?
I don't really know, but I suspect that it doesn't matter.
