February 1, 20233 yr Noticed that solar assistant just stopped this morning at 5am. I cant connect to it via bluetooth to check what happened. I see its connected to the network and is assigned an IP. Not sure what to do next.
February 3, 20233 yr Author This was sorted. Turns out my raspberry pi PSU was failing and causing a continuous boot loop. Powering a with an iphone dongle which is 5V 2A and working great. Edited February 3, 20233 yr by Jack Kitley
February 3, 20233 yr 15 minutes ago, Jack Kitley said: This was sorted. Turns out my raspberry pi PSU was failing and causing a continuous boot loop. Powering a with an iphone dongle which is 5V 2A and working great. Good, one can never overemphasize the importance of quality and reliable 5V feed to embedded microcomputers, especially when they serve 24x7. Edited February 3, 20233 yr by BritishRacingGreen
