February 7, 20233 yr Hallo All, The Code thats flashing on the Master is a HS, and according to the manual it indicates that's the Master unit. Another problem that happens mostly at night, but also at day time, during load shedding is, the Slave switches off, and stays off until theirs Utility. Now, I do have my Setting 01 on SUB, 12 on 51V, and 13 on 53V. My PV are only connected to my Master, can someone help please. Thanks I have 2x 5.6kva Kodak inverters in Parallel.
February 7, 20233 yr Hi Please can you give us more information: What Batteries do you have? What settings have you set your BMS communication to on Master and slave, Slave should be set to USE. What Firmware do you have on each inverter?
February 8, 20233 yr Author Hi There. I do have 3xSDA10-48100L5 Shoto Lithium Batteries, and 2x 5.6 Off grid Inverters linked together. The one is a newer one than the other, and i dont now whats the Firmware, on both (had Mecer before, and I'm battling to set up the WiFi). Both Master and slave are set to USE. What I have done in the meantime is to separate the Neutrals from the main incoming neutral, and it seem to work fine. No problems after that. Thank You Edited February 10, 20233 yr by Swannie
February 10, 20233 yr Author Morning There, just to clarify the above post. It was the idea of a Qualified Electrician to do this. It worked for me. So If we are wrong, pleas tell me. Thanks
February 10, 20233 yr Hi Swannie - I am glad to hear the issue seems to have sorted itself about after separating the neutrals from the main incoming neutral. As long as both inverters are set up the same with the same parameters and in Master Slave configuration you should be good to go.
June 13, 20233 yr Does anyone on here have a Shoto SDC10-Box5 connected to PC via Seplos Battery management software? I am looking for the parameter file for those batteries
