February 27, 20233 yr Hello This is purely out of curiosity... Lets take the Sunsynk 5.5K inverter configured with the same battery discharge and charge rates with no solar. When will the inverter be running the hottest? When charging the battery or discharging the battery or will it be the same? Thank you Edited February 27, 20233 yr by TheMac
February 27, 20233 yr 8 minutes ago, TheMac said: Hello This is purely out of curiosity... Lets take the Sunsynk 5.5K inverter configured with the same battery discharge and charge rates with no solar. When will the inverter be running the hottest? When charging the battery or discharging the battery or will it be the same? Thank you A thumb suck will be it will be the same. This is based on the charge/discharge current set at the same value. Would also like to know.
February 27, 20233 yr Charging is done at a higher Voltage than discharging. All other things being equal, that gets my vote. However I'd expect the BMS to have an unknown impact on the charging and discharging cycle that could throw any theory I could offer out the window.
