February 28, 20233 yr Good day I recently installed 6 * 480w Sunmagic Solar panels. Its currently producing around at most 1kwh at peak sun times. The average volts is around 170v and rarley reaches 200v. Please advise if this is what is expected.
February 28, 20233 yr How are they wired up to the inverter (How many panels per mppt?)? Are they wired in parallel or in series? What Inverter (make and model) are they wired to?
February 28, 20233 yr Can you trust something with the name magic? Voltage seems low you would need to test amps with a dc clamp meter. 1 bad panel in a series string can drastically lower power output Edited February 28, 20233 yr by Chris_S
March 1, 20233 yr Author On 2023/02/28 at 10:00 AM, mzezman said: How are they wired up to the inverter (How many panels per mppt?)? Are they wired in parallel or in series? What Inverter (make and model) are they wired to? They are wired to a Luxpower SNA 5kva with 6 panels in series
March 1, 20233 yr Author On 2023/02/28 at 12:07 PM, GreenFields said: Any shade on any of the panels? All panels pointing in the same dirsction? No shade at all and in a North to North West direction.
March 1, 20233 yr Author On 2023/02/28 at 10:04 AM, Chris_S said: Can you trust something with the name magic? Voltage seems low you would need to test amps with a dc clamp meter. 1 bad panel in a series string can drastically lower power output Does seem like are magic coming from the sun......LOL
March 1, 20233 yr On 2023/02/28 at 9:56 AM, CG26 said: Good day I recently installed 6 * 480w Sunmagic Solar panels. Its currently producing around at most 1kwh at peak sun times. The average volts is around 170v and rarley reaches 200v. Please advise if this is what is expected. With the current sun you should be getting around 2300W if you have enough load on and battery is discharged. Current production.
March 1, 20233 yr 58 minutes ago, Scorp007 said: With the current sun you should be getting around 2300W if you have enough load on and battery is discharged. Current production. What app is that?
March 1, 20233 yr Author 1 hour ago, Scorp007 said: With the current sun you should be getting around 2300W if you have enough load on and battery is discharged. Current production.
March 1, 20233 yr Author 5 hours ago, Chris_S said: What app is that? Thats the inverter app Luxpower inverter
March 1, 20233 yr 7 hours ago, Chris_S said: What app is that? This is a basic APP for Solis inverters. No fancy graphs.
