Sunmagic Solar Panels
Good day
I recently installed 6 * 480w Sunmagic Solar panels. Its currently producing around at most 1kwh at peak sun times. The average volts is around 170v and rarley reaches 200v.
Please advise if this is what is expected.
Can you trust something with the name magic?
Voltage seems low you would need to test amps with a dc clamp meter. 1 bad panel in a series string can drastically lower power output
Edited by Chris_S
On 2023/02/28 at 10:00 AM, mzezman said:
How are they wired up to the inverter (How many panels per mppt?)?
Are they wired in parallel or in series?
What Inverter (make and model) are they wired to?
They are wired to a Luxpower SNA 5kva with 6 panels in series
On 2023/02/28 at 12:07 PM, GreenFields said:
Any shade on any of the panels? All panels pointing in the same dirsction?
No shade at all and in a North to North West direction.
Does seem like are magic coming from the sun......LOL
On 2023/02/28 at 9:56 AM, CG26 said:
Good day
With the current sun you should be getting around 2300W if you have enough load on and battery is discharged.
Current production.
Current production.
What app is that?
Current production.
