March 6, 20233 yr Hi All, My first stab at wiring my system. I will update this post with the latest version of this diagram as I learn more. Hopefully this will help the next person. This is where I need your help - To learn more!!! Please critique the diagram and point out any mistakes I have made. Wiring diagram made using Drawio Feel free to reuse in your own project The software is free - available @ https://www.diagrams.net/ I have attached a jpg version and the drawio version for you to use in your own project Check back to see if version number changes to see if you have the latest Updates v1.2 Updated EN Bridge (hopefully correct) WireDiagram_v1.2.drawio Edited March 6, 20233 yr by Marksmith4x4 v1.2
March 6, 20233 yr You need to change the "AC Disconnect Inverter" to a "Changeover switch" which can bypass the inverter and supply the Sub DB directly from Eskom in case that's required - e.g. inverter fault, repair, etc.
March 6, 20233 yr Author 3 minutes ago, PowerUser said: You need to change the "AC Disconnect Inverter" to a "Changeover switch" which can bypass the inverter and supply the Sub DB directly from Eskom in case that's required - e.g. inverter fault, repair, etc. Thanks - that's probably a good idea - never thought of that.
March 6, 20233 yr Author Question around the EN-Bridge: Sunsynk manual states: "Do not connect this terminal [PE] when the neutral wire and PE wire are connected together." Does this mean that I need to remove the load PE connection completely? OR Have a second contactor that only passes PE on load when ATS is NOT engaged? Edited March 6, 20233 yr by Marksmith4x4
March 6, 20233 yr Author Question around the EN-Bridge Continued .. Based on the manuals instruction then this should be correct?
March 6, 20233 yr Author 1 hour ago, Marksmith4x4 said: Question around the EN-Bridge Continued .. Based on the manuals instruction then this should be correct? Scratch that - Removed load PE + Passed PE directly through + Bonded load N to PE
March 7, 20233 yr Author Found a simple document for EN Bond. In case someone needs it - attached. SS EN Bridge.pdf
March 7, 20233 yr Author If there are any qualified electricians that read this - I would love to have your feedback on DB board wiring. Would it pass SANS 10142 inspection?
August 18, 20232 yr @Marksmith4x4 Thank you for sharing this. I am busy with my DIY solar project and your diagram will certainly assist. I am "lucky" as all my loads will be on essential.
