need watch power WIFI alternative free android app
Hi Barendkoorts
Is it free or paid and I'm may be looking to get Hubble cloud link because I have Hubble battery's but it is pricy same as solar assistant look like i must get one off them to get proper info on system
Hi @Riaancam - I can most definitely recommend the Hubble Cloud Link as an alternative solution. Whilst it may seem pricey you get what you pay for. Remember that in choosing the Cloud Link you have also got back-up support locally and the interface is extremely well put together and easy to use. I hope this helps.
Hi . just a question why don't kodak and other Axpert inverter company's offer a better app like the Sunsynk app that show a lot of information and history . second question I'm want to know if a program or app is available to decode the history logfile for kodak OG 7.2 to see my total trend from installation date
Gosh how perception differ.
I installed an AM-2 with cloudlink for a neighbour a couple of years ago and am still embarrased that I fell for all the hype.
Below an example of what I consider not a great interface.  Not very informative, is it? (It has been like this through several upgrades...)
Hi @SEGEN SOLAR  i did install the cloud link and it give me all the info i want but i have some settings I'm not sure about  like the can settings and the SCM settings all is on default still
inverter is a kodak OG7.2 with 2 x AM2 battery's with a Cloudlink  connected to inverter via rs232 and battery via can cable
Edited by Riaancam
If i understand it correctly that info is only available if you use S-port on cloudlink connected to master battery via the RJ12 plug
I set this up for my brother who has the 5.6 Kw Kodak... just need a pi and some IT experience.  https://github.com/BionicWeb/AxpertPi You do need to set the MQTT settings as they are broken on startup, but let me know if you need help.
it's based on the below setup  https://github.com/ned-kelly/docker-voltronic-homeassistant
There seems to be some pretty good support.
