March 25, 20233 yr Sorry for bumping in.... I have a problem where my timer settings, for some reason, still goes to the grid, even though all grid settimgs are disabled? See attached... Time slot 2 is switched for 23:00 to 03:00 in the morning...looki g at the settings, grid is switched off and everyday the graph shows that time slots pulling from the grid? Restarting the system did not work. If anyone can help it would be highly appreciated!
March 25, 20233 yr Try not changing the default time slots , start at 1am in time slot 1 and work from there . The timeslots have to follow each other .
March 25, 20233 yr Author Thanks for the tip. As soon as I get home I will let you know, maybe give you a pic of the inverter settings as a whole. Been reading a lot of your posts. Thanks!!!
March 25, 20233 yr Yeah we need more info and pics of your system mode screens from the inverter... Also more info around your setup (how many batteries etc)
March 26, 20233 yr I am experiencing similar problem since Friday, the timer worked 100% until Friday. I do have a 8kw sunsynk with 10kw AM-10. The inverter doesn’t use any battery power except when grid is off
March 26, 20233 yr @Hps Under "System Mode", tab 2 called "System 2". Ensure that "Prioritize load" is checked Edited March 26, 20233 yr by MeepMoop @user
March 26, 20233 yr Author I will send a pic as soon as I can get home. Sunsynk 5Kw with a 5.5 Hubble AM-2 battery. Dont think the solar panels are relavant at thi stage... I am looking into a 1.5Kw 48v wind turbine inclusion, but I just need to sort out all the nook and crannies of this issue first...
March 26, 20233 yr Author As promised, pics of setup... I am in the process of changing the timer settings to what Nexus suggested.
