Home Assistant Newbie
Hi all,
Slowly moving the house over to some smart switches and lights.
Are there any decent templates I could use to minimise setup / config time? All light switches are Eachen 1 and 2 gang switches. Outside lights, pool motor and geyser are on Sonoff.
Stove and geyser are on none essential loads.. Current setup is a Sunsynk 5KW with Hubble AM-2.
Any advise / direction would be appreciated.
Thanks,
Kevin
Hi Kevin
The Actual automation config on Home Assistant is pretty easy, a few googles and some testing you'll be fine. What takes some time is configuring all the setting up all the integrations. I do know you need to install HACS on HA in order to get the Sonoff connected (no need to flash the sonoff's). As for Sunsync if you already have solar software like ICM or SolarAssistant this could be a little easier. I can help with ICM. If not you'll need to use some custom developed software for home assistant in order to pull in metrics.
