April 29, 20233 yr On the Powerforum Store, there are 2 models available One is a Kodak unit for R19423,00 Another is a Solax X1 for R30654,00 The specifications appear very similar to me. Does the R10000,00 premium ensure better performance, reliability or something else? Thanks
April 29, 20233 yr 1 hour ago, chrisc said: On the Powerforum Store, there are 2 models available One is a Kodak unit for R19423,00 The Kodak I see on the store is an off grid inverter. A R10k premium for hybrid functionality is worth it in my mind.
April 30, 20233 yr Author Most customers I have met are not interested in feeding back to the grid All they need is for an inverter to charge the battery from PV panels or the mains and supply AC all the time, whether from PV panels or in Bypass mode from the mains
May 1, 20233 yr 10 hours ago, chrisc said: Most customers I have met are not interested in feeding back to the grid All they need is for an inverter to charge the battery from PV panels or the mains and supply AC all the time, whether from PV panels or in Bypass mode from the mains Thats very true. However, it must also be said that an inverter feeding back can be configured to feed back within the limits of the owners own non-essential circuits, and not outside these bounds. This is powerfull feature when you have enough pv power to augment power to geyser / stove etc. during the sunny hours. And the magic of this is that if even only 2kw excess pv power may be available, that 2kw will add to even a 6kw demand on the nonessentials. BUT, nothin is without T&Cs, this requires mains grid to be available. EDIT: but if you are planning to become more and more Escom independant, you are expecting the future to be even bleaker as it is now in terms of grid stability, then the gridtie offering will play a lesser role, and you might look at offgrid inverter. Edited May 1, 20233 yr by BritishRacingGreen
