Inverter limits with no load shedding
I will install a 8kw inverter with my solar system. Does this mean I will be limited to 8kw usage even when there is no load shedding.?
I am still in the process of evaluating my options. Will some inverters limit the usage when there is no load shedding and others not.? I will probably use a Sunsynk hybrid inverter.
With a Deye / Sunsynk 8kw you will be limited on your Load when there is no loadshedding to approx 12kw - but i think some have seen higher.
