May 12, 20233 yr Hi all, I cannot for the life of me get my growatt datalogger to connect to my Growatt SPF5000ES inverter it was supplied with. I've logged into the datalogger and tried setting it up on both a 2.4G and 5G wifi network and still no luck. I've gotten the datalogger light to flash green, flash blue, stay solid green, solid blue whilst trying to set it up and still cannot get it to work. I've tried to set it up on standard mode and hotspot mode with still no luck. the error I keep on getting is as per the attached screenshot on the shinephone app. Is there something I am doing wrong or could there be a fault with the datalogger? Any and all help is appreciated. Thanks in advance!
May 13, 20233 yr Author Found this on a previous post from HAM -> For anyone finding this in future, it is a bad idea to use any old installer code. This will add your datalogger to that installer's account. Unless you don't mind a random person knowing about your installation, I would not do this. If you want your own installer code use this site to register for a code: https://oss.growatt.com/login?lang=en
May 15, 20233 yr Reset the datalogger settings by pressing the LEDs for 10 seconds. Connect to the logger and enter 192.168.10.100 in your PC browser and log in to its website. Login: admin, password: 12345678. There you will find the logger configuration where you enter the data of your WIFI network. You confirm, you leave and the logger should flash blue.
May 15, 20233 yr Author Hey Remus, I have done that about 5 or 6 times, trying both my 2.4G and 5G wifi network and still no luck.
May 15, 20233 yr Author Hey Remus, followed your steps again. reset the datalogger and its flashing blue but Im still ending up on the same configuration error screen on the app.
May 16, 20233 yr Author Finally got it to work last night. Followed all the steps which I have previously done about 20 times. however this time I logged out of the ShinePhone app and then logged back in and straight away tried to pair the datalogger and it worked like a charm. I suspect it must've been a bug on their side. Thanks for your assistance Remus.
May 26, 20233 yr On 2023/05/15 at 12:35 PM, remus74 said: Reset the datalogger settings by pressing the LEDs for 10 seconds. Connect to the logger and enter 192.168.10.100 in your PC browser and log in to its website. Login: admin, password: 12345678. There you will find the logger configuration where you enter the data of your WIFI network. You confirm, you leave and the logger should flash blue. Thanks, will try..
January 8, 20251 yr Boys I need help please. I bought a house with Growatt solar and all works fine except - i cannot use the datalogger. The stick under my inverter is a RS232 wifi stick and I have a Shinelanbox. I put the shinelanbox on my lan and connected to it via IP. I dont have the login and password and cannot get it from previous owner. I tried admin 12345678 and admin admin but no luck. Any idea how i can reset the shinelanbox to factory user and password please? thanks ant
July 30, 20251 yr Hola buenas noches tengo un problema con mi dataloger al programarlo por primera vez, sale un recuadro que dice " el nombre del wifi conectado es diferente del nombre del dataloger " alguien puede orientarme por favor.Se los agradecería muchísimo
October 14, 2025Oct 14 Hi,I also had the same issue. I have reset the WiFi dongle many times, but data didnot appear in the ShinePhone app. But it showed the router is connected to WiFi, but the server is not accesible. I wrote to Growatt and they reset password of my ShinePhone app account. Next, I logged out of the account and logged in again using the new password. Now I could see the data in the phone app live! I hope this information will be usefull for someone.Regards,Rohana
July 31Jul 31 My dongle is connecting to my router but not to the server--tried resetting, deleting dongles, deleted the app , reinstalled the app,,even created a new account, but data logger only connects to the router and not server !!!! Please some help here
July 31Jul 31 After I do a full reset I can connect to the datalogger`s wifi but I can not connect to the GUI of the datalogger---error refused connection---Next time I am using a hammer for complete reset !!!!
