June 30, 20233 yr It really depens on which inverter you have. I have the Kodak Hybrid off grid 7.2kW and it cannot start without a battery. Friend of mine has an older Goodwe 6kW grid tied inverter and it can start without a battery.
June 30, 20233 yr 14 hours ago, gryphon25 said: Can you power up an inverter with AC without connecting a battery? Battery-less operation is a feature of some inverters,not all
July 6, 20233 yr Author Sorry for little info before. It's a SUN 2kva inverter. It didn't work without the battery connection
July 6, 20233 yr Author Does anyone have any info about these inverters? The fan on mine just keeps running even when it's on AC bypass.
July 6, 20233 yr I think an inverters core function is to produce 220V AC either from battery or from PV. True hybrids do it from either/both.
July 7, 20233 yr 15 hours ago, gryphon25 said: Does anyone have any info about these inverters? The fan on mine just keeps running even when it's on AC bypass. Some always stay on and ramp up. Budgetish ones tend to be louder-er permanently
July 8, 20233 yr Author On 2023/07/07 at 12:21 PM, PsyWulf said: Some always stay on and ramp up. Budgetish ones tend to be louder-er permanently OMG. I can't cope. I have it in the living room at the moment and was planning to mount it in my office. Guess I'll just have to keep my noise cancelling headphones on 😔
July 8, 20233 yr On 2023/06/30 at 8:11 AM, Proff72 said: I have the Kodak Hybrid off grid 7.2kW and it cannot start without a battery. The Kodak 7. 2 actually can power up from grid only, or pv only. So it does not insist on battery power being available.
July 8, 20233 yr growattspf5000es runs perfectly without a battery but you need to decent solar panels and NO clouds. Not really recommended/ideal to run like this. You would rather run a grid-tie inverter if you do not have batteries. Edited July 8, 20233 yr by WannabeSolarSparky
January 1Jan 1 On 2023/06/29 at 11:26 PM, gryphon25 said:Can you power up an inverter with AC without connecting a battery?
