July 14, 20233 yr With all the changes in Load Shedding levels I thought it would be a good idea to a video on a really easy way to switch your inverter between settings. Works really well and pretty easy to do. Only working with the ESP32 integration as that allows for the changing of inverter settings as default Maybe @Gary Waterworth and @stephanjoubert can let us know if it is possible to write settings back to the inverter using their integrations Edited July 14, 20233 yr by Sc00bs
July 14, 20233 yr 2 hours ago, Sc00bs said: With all the changes in Load Shedding levels I thought it would be a good idea to a video on a really easy way to switch your inverter between settings. Works really well and pretty easy to do. Only working with the ESP32 integration as that allows for the changing of inverter settings as default Maybe @Gary Waterworth and @stephanjoubert can let us know if it is possible to write settings back to the inverter using their integrations There are ways to do it, but it involved extra coding in the node red flows.
July 14, 20233 yr Author 2 hours ago, Gary Waterworth said: There are ways to do it, but it involved extra coding in the node red flows. Thanks Gary, Sounds like the best option is to get an ESP32
July 14, 20233 yr Author 4 hours ago, mzezman said: Nice one @Sc00bs Thanks @mzezman Just need to automate the changes now when load shedding level changes 🙂
July 15, 20233 yr Author On 2023/07/14 at 3:52 PM, Sc00bs said: Thanks @mzezman Just need to automate the changes now when load shedding level changes 🙂 I think I have it out, doing a video on it now. Would just like to make sure it works 100% to make sure my Home Assistant doesn't just randomly change my battery settings, lol
July 25, 20233 yr Wow epic that is super cool. Am currently using a Pi and a super old version of your Node Red flows, but have decided to change to Solar Assistant (have ordered the configured Pi). Will definitely be implementing this. I've never really knows how scene's work or what they do.
