Kodak Max 7.2Kw In Parallel - Transfer Time
Good evening All
I trust that you are all well.
Yesterday late afternoon, early evening I commissioned the following system:
3 X Kodak Max 7.2Kw units in parallel and 4 X Greenrich 3.686KWh batteries in parallel which are communicating with the Kodak master inverter via the Pylon cable which came with the inverters. The firmware version of all 3 inverters are U1: 69.05, U2: 12.21, U3 0.0
This afternoon I noticed that when the inverters are changing over from utility power to battery power that the output is off just long enough so that one of my computers is turning off and back on, now will there be a difference in transfer time if I use UPS instead of APL for program 3?
When the utility is back the computer does not switch off when switching between battery power and utility power.
At the moment I do not have any solar panels connected to any of the inverters so SUB option for program 1 is not an option.
Kind Regards
GerhardK83
